There are two ways to share your files from Aloha app to other devices using the same wifi network:
Wifi file sharing to other devices with IP address
1. Go to Aloha downloads Settings:
2. Enable wifi file sharing switch:
3. Open given IP address in any other device's web browser:
4. Once you enter IP address in the web browser, your files will appear on the screen and you can start managing your files: Create new folders/Download selected files/Upload files:
Wifi file sharing to other devices using QR code
3. Tap QR code and it will pop up in full screen:
4. Now, open web browser in another device and activate QR reader:
5. Point camera to scan QR code on your first device:
6. Once you scan QR code, your files will appear on the screen and you can start managing your files: Create new folders/Download files/upload files:
Important: Aloha should be running while wifi file sharing is in process. All transfers will stop when you close the app.
