How to switch site view from mobile to desktop?
1. Open website you wish to see in desktop mode
2. Tap address bar and once the keyboard pops up, you will see Desktop icon in the top right corner above the keyboard
3. Tap Desktop icon and the current tab will be switched to Desktop. Use the same button again to get back to mobile mode (button will change its look to mobile)
Is article helpful?
