Convert Premium to NFT:
- Open https://alohaprofile.com/
- Log in to your profile
- Tap the “Activate” button in the “Premium NFT” section
- Create a wallet or connect to an existing wallet
- Activate your subscription.
With Premium NFT, you can:
- Store it in your wallet and use it as a premium subscription
- Exchange it for any other tokens from our partner Liquid Access
- Send it to someone else
- Sell it if you no longer need it.
