NFT Premium
Convert Premium to NFT:
  1. Open https://alohaprofile.com/
  2. Log in to your profile
  3. Tap the “Activate” button in the “Premium NFT” section
  4. Create a wallet or connect to an existing wallet
  5. Activate your subscription.
With Premium NFT, you can:
  • Store it in your wallet and use it as a premium subscription
  • Exchange it for any other tokens from our partner Liquid Access
  • Send it to someone else
  • Sell it if you no longer need it.
Is article helpful?
