Change playback speed, subtitles, and audio tracks in the web video player on iPhone
To change the playback speed of a web video in Aloha on iPhone, play the video in full-screen mode, tap ⋯ in the top-right corner, and select Playback speed. The same menu lets you choose subtitles and audio tracks when the website provides them.
Change the playback speed
  1. Play a video in full-screen mode.
  2. Tap ⋯ in the top-right corner.
  3. Tap Playback speed and choose a speed.
Hold to play at double speed
Press and hold the right half of the player. The video plays at double speed until you let go.
Choose subtitles and audio tracks
  1. Tap ⋯ in the top-right corner.
  2. Tap Subtitles and choose a language or Off.
  3. If the video has more than one audio track, tap Audio and choose a track.
