1. Open Aloha app
2. Go to Aloha Settings
3. Enter Wallet page
4. Tap Recovery Phrase
5. Slide arrow to Reveal Phrase
6. Write down displayed words in the correct order or copy them to your clipboard
You can now import your existing wallet credentials to any other wallet using the Recovery Phrase:
1. On the launch of your chosen wallet, select 'I already have a wallet'. Then select 'Import wallet'
2. Click 'Recovery Phrase' on the ‘Select Import Method’ page
3. Enter your wallet’s recovery phrase and tap 'Proceed' when you’re ready. Make sure that you’re entering the phrase in its correct order.
Please note that every wallet's instructions and settings might vary, so best would be to consult with their dedicated support agents, if you need more detailed instructions.
