1. What are the Snips, and how are they different from Bookmarks?
Snips are bits of webpages you care about, saved in a collection. They update automatically - no refreshing needed. Unlike bookmarks, which can get lost or forgotten, Snips sit on a dashboard, organised your way.
2. Are Snips available on mobile or just desktop?
Snips are available on both mobile and desktop!
3. How do I know when the price changes for a product I’ve picked?
You’ll get a notification whenever it happens!
4. How can I resize a Snip?
Hover your mouse over the edge or corner of your Snip and resize it as you wish. You can resize it anytime!
5. Can I edit or delete a Snip after making it?
Yes! Click the three dots in the top right corner to rename it, change update timing, adjust AI alerts, or delete it
6. How do I rearrange my Snips?
Just drag and drop them wherever you want - they’re super easy to move!
7. How do I open the full webpage from a Snip?
Click on the Snip, and the whole page will open in a new window.
8. What happens if the webpage I snipped changes or disappears?
If that happens, just delete the old Snip and create a new one.
9. Are my Snips stored online? What about privacy?
Your Snips stay on your device only. We don’t see or access them.
10. What if I have suggestions or find a bug with Snips? How do I report it?
We’d love your feedback. Please report any issues to our team or tell us what you think at support@alohabrowser.com.
