How can I export my Bookmarks from Aloha to other browsers?
2. Go to menu and enter Bookmarks section:
4. Select 'Export bookmarks':
5. Find your bookmarks file in Aloha Downloads section with the title 'AlohaBrowser_Bookmarks'
6. Tap 3-dot icon in the lower right corner of the file:
7. Tap 'Share' in pop up menu:
8. Choose any app in the list - email/drive/messenger/other:
9. Save your bookmarks file (html) from your email/drive/messenger/other to your PC/MAC/any android device and add it to any browser you like.
