How can I transfer Aloha downloads from one Android device to another?
For Premium users
Wi-Fi file sharing
Friendly note: if you are not a Premium user, you can sign up for a free weekly trial and unsubscribe at any time!
Here is why we recommend it:
1. Sharing through the cloud requires cloud (which is also a paid service), at times it's very slow (files are uploaded, and then downloaded again), so if you have, say 15GB of files it will take forever. Wi-Fi file sharing goes through Wi-Fi without using data and it's ten times faster than cloud. Try it for free!
For Standard Aloha users
File transfer via cloud & file manager:
1. Go to Aloha Browser downloads section
2. If you wish to transfer your private files, firstly move it to Device Downloads:
- Enter Private folder
- Long tap any file and then select all remaining files in the private folder
- Tap 3-dot icon in the upper right corner and move selected files to Device Downloads
3. Go to device file manager
4. Find Folder with Aloha Files
5. Select all files and tap Share button
6. Choose any cloud (dropbox/google drive/etc.) in the share menu and store your files there
7. In your new Android device open your cloud and share it to Device file manager, these files will be accessible in Aloha Downloads - Device Downloads folder.
File transfer via SD card:
1. Firstly, if you have any files in Aloha Private folder, move it to public folder:
- Go to Aloha downloads
- Long tap any file and then select all remaining files in private folder
- Tap 3-dot icon in the upper right corner and move selected files to any public folder
2. In any public folder select all the files
3. Tap 3-dot icon in the upper right corner
4. Tap 'Move to folder' then tap SD card in the pop-up menu.
Bookmarks transfer:
2. Enter Bookmarks section in the toolbar
4. Select 'Export' bookmarks in pop-up menu
5. Find your bookmarks file in Aloha Downloads section with the title 'AlohaBrowser_Bookmarks'
6. Tap 3-dot icon in the lower right corner of the file
7. Tap Share in pop-up menu
8. Choose any app in the list- email/drive/messenger/other
9. In another Android device, save your bookmarks HTML file to device storage from your email/drive/messenger/other
10. Then go to Aloha application
11. Enter Bookmarks section in the toolbar's menu
12. Tap 3-dot icon in the upper right corner and select 'Import Bookmarks'
13. Find and tap Alohabrowser_Bookmarks html file from device storage and it will be imported into Aloha bookmarks section.
