How to clear browsing history/cache/cookies?
1. In Aloha app go to 'Settings':
2. Enter 'Privacy' section:
3. In the Menu tap Clear cookies/history/cache or tap 'Clear all':
 You can also use 'Clear history' shortcut button in the Menu:
