How to reset password
1. Go to Aloha app Settings
2. Enter Aloha Profile section
3. Tap Reset Password button
4. Tap Reset Password in the confirmation pop-up
5. You will be emailed with further instructions to your email address associated with Aloha Profile account.
Please note: If you haven't received your password reset link, please check your spam folder or contact our support at support@alohabrowser.com
