1. Go to Aloha app Settings
2. Enter Aloha Profile section
3. Tap Reset Password button
4. Tap Reset Password in confirmation pop up
5. You will be emailed with further instructions to your email address associated with Aloha Profile account.
Please note: If you haven't received your password reset link, please check your spam folder or contact our support at support@alohabrowser.com
