You can upgrade your plan to Premium Plus directly when you use Private AI Assistant. In the dialog box, you can choose between two subscription options - monthly or annual.
- How to Purchase Premium subscription?
- How to Cancel Premium subscription?
- How to request a refund for Premium subscription?
- What Premium plans are available for purchase?
- What are Premium subscription features?
- Can I use my Aloha Premium plan on other devices?
- Can I use free trial to test Premium subscription?
- How to upgrade to Premium Plus subscription?
- What are Premium Plus subscription features?
- Activate Premium with the Promo code
