Passcode set up
If you wish to protect your personal data on Aloha Browser app, we advise you to set up a passcode. It's a simple 4-digit password that will prevent other people from accessing your personal data on Aloha Browser app.
Learn how to set up a passcode on Aloha Browser app:
1. Open Aloha Browser app
2. Go to Settings -> 'Privacy'
3. Enable Passcode toggle:
How to set up Passcode in Aloha Browser for iOS
4. Enter 4-digit password:
5. Re-enter passcode to confirm:
From now on, Aloha app will require a passcode every time you open the application.
You can also set up a passcode for different areas, for example, if you only wish to set up a passcode for Aloha Wallet:
Aloha Premium: Passcode set up for different folders in Aloha Downloads section
1. Go to Aloha Downloads
2. Choose any Folder and tap the 3-dot icon in the corner:
3. Choose 'Lock' from the menu:
