A Traffic Mask is a digital disguise for your internet activity. It scrambles or reshapes your data packets right on your device so your internet provider can't tell what sites or apps you're using—preventing them from blocking or slowing down your connection, without changing your IP address like a VPN does.
You can switch it on in Aloha Settings -> VPN -> Enable the Traffic Mask toggle.
Check out for more info in here: https://alohabrowser.com/posts-introducing-traffic-mask-a-simple-guide/
