Where are my downloaded files stored?
By default all files are automatically saved in the Downloads folder on your Mac.
Here is how you can change Downloads location:
2. In the menu towards the end click 'Additional settings' button:
3. Then, click 'Downloads':
4. Click 'Change location':
5. Select any other section in the list:
6. Then click 'Select' button:
