Aloha Premium: Wifi File Sharing
There are two ways to share your files from Aloha app to other devices using the same Wi-Fi network:
Wi-Fi file sharing to other devices with IP address:
1. Go to Aloha Downloads Settings.
2. Enable Wi-Fi file sharing toggle:
3. Tap share button and select any app you wish to use for link sharing in the pop up menu:
4. Copy and open given IP address in any other device's web browser.
5. Once you enter IP address in the web browser, your files will appear on the screen and you can manage your files: Create new folders/Download selected files/Upload files:
Wifi file sharing to other devices using QR code:
2. Enable Wi-Fi file sharing toggle.
3. Tap QR code button and code will pop up in full screen:
4. Now, open web browser in another device and activate QR reader.
5. Point camera to scan QR code on your first device.
6. Once you scan QR code, your files will appear on the screen and you can manage your files: Create new folders/Download files/upload files:
Is article helpful?
