Warning:
JavaScript is required for this website to function properly.
Aloha Browser
Topics
New Topic
Login
Aloha Browser
Browser types
How do I browse on a 'Normal' mode?
Where Do I find 'Private' mode?
How do I browse on 'Private' mode?
How can I open multiple tabs?
How can I see all my opened tabs?
How can I close opened tabs?
How to switch site view from mobile to desktop?
Quick access to your browsing history
How can I make Aloha app my default browser?
How to change my default search engine?
How to open new tab shortcut?
How to change language in Aloha browser?
How to use Paste and Search option?
How to use Paste and Go option?
How to create a new tabs group?
How to move tabs to specific Tabs Group?
How to delete tabs group?
1. Go to tabs section
2. Tap 'X" on the upper right corner or tap 'Close all' to exit all the tabs:
0
0
Please help us make article better!
Submit
No connection
Real-time notifications may not work
