Exactly the same way you browse on a Normal mode, plus you can add VPN service for complete security.
- Browser types
- How do I browse on a 'Normal' mode?
- Where Do I find 'Private' mode?
- How do I browse on 'Private' mode?
- How can I open multiple tabs?
- How can I see all my opened tabs?
- How can I close opened tabs?
- How to switch site view from mobile to desktop?
- Quick access to your browsing history
- How can I make Aloha app my default browser?
- How to change my default search engine?
- How to open new tab shortcut?
- How to change language in Aloha browser?
- How to use Paste and Search option?
- How to use Paste and Go option?
- How to create a new tabs group?
- How to move tabs to specific Tabs Group?
- How to delete tabs group?
