How can I enable Bin folder in Aloha downloads?
1. Go to Aloha Settings
2. Enter Downloads settings:
3. Enable 'Move to Trash' toggle:
All your deleted files will be stored in the Bin folder for 30 days and then will be deleted automatically.
