How do I start using Aloha VPN
1. Launch Aloha VPN app on your device
2. Tap 'Continue' and tap 'Allow' in the pop-up to install the VPN profile:
How do I start using Aloha Browser VPN
3. Then tap 'Connect':
4. Start a free trial or restore purchase:
6. Once you have completed your purchase, you can start using device-wide Aloha VPN! Enjoy!
