How to create Bookmarks?
There are a few options:
1. Open Aloha window
2. Insert any web address in the search bar and enter:
3. Click the star icon in the toolbar:
4. Select Bookmarks folder:
5. Then hit 'Done':
1. Tap 3-dot icon in Aloha's toolbar:
2. Enter Bookmark Manager:
3. In the Bookmarks page tap 3-dot icon in the upper right corner:
4. Select 'Add new bookmark':
5. Insert Website name and Link, then click 'Save'
