How to Reset my password?
2. Click 3-dot icon:
3. Enter 'Additional settings':
5. Click 'Reset password' in the list:
6. Then confirm action with 'Reset password' button:
7. You will be emailed with further instructions to your email address associated with Aloha Profile account.
Please note: If you haven't received your password reset link, please check your spam folder or contact our support at support@alohabrowser.com
