VPN NOT WORKING (WINOWS 10 PRO 64BIT)
Solved MU ● 3 years ago
the vpn was working but suddenly its not after the latest update
so when i click the shield it is blinking and go to gray again
i tried to start and restart the aloha service and restart aloha several times and didn't work nothing works!
so i wish there is some solution here
Replies (1)
Hi,
Thanks for your message.
Please go to Aloha Settings - About - Feedback - in the form please explain errors you are experiencing in great detail and attach screenshots/screen-recording of the issue, then tap 'Send'. Thank you,
Regards,
