VPN and synchronization are not working
Solved Shpitz ● 3 years ago
После переустановки браузера не работает впн. Куплен премиум аккаунт, но при авторизации на ПК не работает синхронизация.
Replies (1)
Hi there,
Thanks for posting! On your PC re- log in to your Aloha Profile and make sure that sync is enabled in your mobile in Aloha Profile account.
In regards to VPN, what is your country of residence?
Russia. Before the upgrade to version 1.1.0.0, everything worked
Russia has restricted all our VPN servers hence the error.
The laptop has an old version 0.7.1.0 and everything works. Why?
