Upvote 2
VPN connection problem
Solved حسن الصبيحة ● 3 years ago
Hello, I have a problem with the browser version of Aloha. Whenever I turn on the VPN it always connects two server. Some sites doesn't open because of that.
You can see from the attach file that is connect the normal falsest server and any country server. This happens after I updated my Aloha browser to the latest version.
Replies (5)
I uploaded another file just to see exactly the problem.
I am using version 1.1.1.0
Thanks for reporting!
Please add log file: On your PC open "C:\Users\%USER_NAME%\AppData\Local\Temp" (where %USER_NAME% - current user name) and send file "aloha_vpn.txt" to us.
Thank you,
I have send the file .
Thank you.
Thank you! We have traced the issue and it will be fixed in the next release, so please stay tuned!
Than you very much for your hard work and the Aloha team.
Looking forward to it.
Good day, I have face the same issue that the VPN connects 2 server as you can see down below.
47d92fb9c72e5016c7f4e939d5579a0f
I have send the vpn.txt to see if you could look up for the problem.
Thanks,
