Upvote 2
Hello , so im having a problem on iOS 17.2 Im trying to clear aloha data , Ive tryed everything
Solved Lancey ● 3 years ago
I’ve tryed contacting Apple suppprt they were no help like usual, It’s a specific site that when I press the in the site it just refreshes goes to a grey screen crashes my app and just wont work at all , this is why I’m trying to reset my data
Replies (2)
Good day,
Thanks for your feedback. What site is it and what Aloha version do you currently have?
Regards,
Site is pornhub , latest version of aloha
Can you try the site with disabled Adblock please?
Just did it still don’t work , in the site there’s a desktop version when you scroll down on the site homepage that works fine but the mobile version is messed up it flickers and makes my device lagged it never happened before I updated aloha and this problem started
It seems that this is related to iOS beta version, we will wait for another couple of beta version releases and follow up with this issue.
Regards,
I can downgrade my iPhone to version you guys have that’s stable ?
This is related to iOS beta and not our version (most probably).
So you can try to disable beta on your device:
How to downgrade from an iOS beta
  1. Open Settings.
  2. Tap General.
  3. Tap Software Update.
  4. Tap Beta Updates.
  5. Tap Off.
When is next update for later versions of ios
We cant say, its up to iOS devs!
UNRESOLVED BUG: This issue was marked resolved in error by whomever is running this community forum. The latest Aloha Browser update has not fixed this reported issue which is not rooted in an iOS 17.2 either from the Apple development side. Other websites work just fine via Aloha Browser on iOS, turning AdBlocking/VPN service on or off does not change inability to load pages, either. Other iOS browsers work as expected. I recommend that you re-open this issue. I will create a new topic repeating this information.
