Vpn problem
Solved kuxa ● 2 years ago
Aloha browser, Windows 10, VPN dont working, when I press the lightning icon VPN in the top, it just flashes, but VPN does not activate, please Help!!!
Replies (9)
Hi there,
Please restart VPN service:
1. Type in windows search bar “Services”
2. Find “AlohaMobile VPN service” in services list
3. Click right mouse button on service and select “Start” on context menu.
It should do the trick!
The Windows Service has only- Aloha Mobile Service and the start is already activated. I have restarted this service and still does not activate Vpn
четверг, 28 декабря 2023 г. в 08:55 +01:00 от support@alohabrowser.com <support@alohabrowser.com>:
Please add report: On your PC open "C:\Users\%USER_NAME%\AppData\Local\Temp" (where %USER_NAME% - current user name) and send file "aloha_vpn.txt" to us. Thanks,
Пятница, 29 декабря 2023, 8:40 +01:00 от Aloha Browser <support@alohabrowser.com>:
Thanks for the log, what is your country of residence currently?
Germany
Germany
пятница, 29 декабря 2023 г. в 13:15 +01:00 от Aloha Browser <support@alohabrowser.com>:
It seems that you are using outdated browser version, please update it to the latest and then send the log once more. Thanks a lot!
Aloha version 1.4.0.0
