VPN Problem.
Solved Berk ● 2 years ago
Hello, Aloha support team.
I'm having a VPN problem, I can't open my VPN. When I press the VPN button, it only flashes for 10-15 seconds and connects to a server, then cuts its own connection instantly.
Replies (2)
Hello,
Thanks for the log, we will look into it at the earliest 🛠️
Hello,
thank you for your enquiry.
Apparently, your internet provider is blocking VPN traffic.
You can try to change the internet provider.
-- Aloha developers team.
I understand, but i can use vpn on mobile app.
