Freename.io Web3TLD .247 not working
Solved Adam Holms ● 2 years ago
I got an email from Freename.io that their TLDs would work natively with aloha browser, which I think is great. When I tried to use my domain learnmeditation.247 it did not work. I can use it on the freename.io chrome extenstion and it works fine.
I was hoping you could look into making .247 work on the browser.
Web3TLD.com has the full list of my TLDs with Freename.io
Kindest Regards
Replies (10)
Good day,
Thanks for your feedback. What device model, Aloha and OS versions do you currently have?
Regards,
EditionWindows 11 Home
Version22H2
Installed on‎2/‎12/‎2023
OS build22621.3007
ExperienceWindows Feature Experience Pack 1000.22681.1000.0
Version 1.4
Version22H2
OS build22621.3007
Not sure where I find the version of Aloha that I am using
1e566fa84787f854f226741967d457fa
2
Good day! Please restart Aloha, then wait around 1 min and try to open learnmeditation.247. It should work as expected 🤝
So right now the domain learnmeditation.247 is being forwarded via the freename.io system to LearnMeditationFree.com. When I do as you said in your reply above I get the following page.
b907a102f36cae98f1924f962a89c0dd
There is nothing much we can do about redirects though. This is not Aloha’s doing.
OK, no worries. So as long as it is connected to IPFS/IPNS it should work?
Hi again,
We did a research and it seems that Freename web3 sites works only on mobiles for now. You can use ios/android on this particular website and its should open correctly 👌
Update:
Turns out, it is broken in Android too due to it being iOS exclusive feature.
It will be fixed in Aloha/Android 5.8.
Regards,
Address not found
Your message wasn't delivered to support-user@alohabrowser.com because the address couldn't be found, or is unable to receive mail.
LEARN MORE
The response was:
550 5.1.1 The email account that you tried to reach does not exist. Please try double-checking the recipient's email address for typos or unnecessary spaces. For more information, go to https://support.google.com/mail/?p=NoSuchUser v2-20020aa7d802000000b00565ac0c9dfesor2973547edq.10 - gsmtp
