Problem with vpn in iphone. Works with wifi but not with mobile data since a day ago
Solved lull ● 2 years ago
Just like the title says. I can use von with wifi/wlan at home and so but not with my mobile data from my provider anymore.
It started a day ago and when I tried to “network testing”, none of them had connection with the mobile data but with wifi.
Replies (2)
Good day,
Thanks for your feedback. It looks like your mobile data admin is blocking our servers intentionally. Best would be to consult their support directly.
Regards,
Like I said, it started a day ago and what kinda provider would be able to do that? What purpose? So for what would be a vpn worth? It makes no sense at all
What is your country of residence?
Switzerland
If that would be the case, my wlan would probably be blocked too cause it’s from the same provider
