Upvote 2
Still not solved storage problem its been months
Solved ahmed_7476ttr ● 22 months ago
I’ve sent reports and updated the app and paying premium and to be honest just fed up of you guys saying it’s getting solved.
Why is the app using the extra storage why can’t you help me clear it ?
Replies (1)
Hi, we have asked you to send another report after updating, still waiting.
Regards,
I am still having this problem
It’s baffling that you guys can’t solve it after months of waiting
The discrepancy between the file sizes shown in the two screenshots is because they're measuring different aspects of the Aloha app's storage usage:
In the first screenshot (iPhone Storage):
  • App size - This represents the installed application code itself
  • Documents and data - This represents user data stored by the app
In the second screenshot (Aloha Files page):
  • "Aloha files" - This specifically shows files stored by Aloha that are accessible through the device's file system
The difference occurs because:
  1. The first screenshot shows the total app footprint (both the app binary and all its data)
  2. The second screenshot is showing only user-accessible files that Aloha has created
Most of Aloha's of "Documents and data" are likely stored in app-specific directories or databases that aren't directly accessible through the device's file system, which explains why not all Mbytes appear as "Aloha files" in the storage management view.
This is absolutely normal practice for browsers and file download applications. Browsers often store a significant amount of data in the cache, temporary files, and other service storages.
