Basic Plan VPN not working
Solved Adam Apple ● 19 months ago
Hi, since past week my VPN isn’t working at all, basic plan , please check
Replies (7)
Good day,
Thanks for your feedback. Please reinstall Aloha VPN profile and try the servers again:
For iOS users: Go to Aloha VPN settings - Tap Remove Aloha VPN profile - Exit Settings and tap shield icon to reinstall Aloha VPN profile.
For Android users: Go to device settings - Connections - VPN - Aloha VPN - Remove Aloha VPN profile - Go to Aloha app - tap shield icon to reinstall Aloha VPN profile.
Let me know if it helps.
Regards,
Hi I tried that, it didn’t work.
Hello please help vpn isn’t working basic plan
Hello?
Hi,
- what is your country of residence?
- what error is displayed when you enable VPN service?
- what Aloha versions and Android/iOS versions do you use?
Thank you,
1) Qatar
2) There No error displayed, vpn shows connected, but doesn’t load anything , not even Google.
3) iOS , Aloha v7.0.0
Please check the following screenshots
It is tricky with VPN in Qatar, as your local network providers are often blocking VPN servers.
I can only suggest to switch to another wifi network or mobile data.
Regards,
