How to disable running on startup
Solved Temi ● 15 months ago
After installing Aloha on desktop when I go to task manager I noticed aloha_service.exe running in the background every time I start my PC even if I don't launch the browser
Is there a way to disable this ?
Replies (3)
Good day,
Thanks for your feedback. aloha_service.exe is not the main application (aloha.exe), but rather a background service.
It runs in the background to handle essential tasks, even when all browser windows are closed, such as:
  • Receiving notifications
  • Automatically updating extensions
  • Synchronising data (if enabled)
  • Managing update services
This ensures a smoother and more up-to-date browsing experience.
Regards,
But can it be switched off ?
I have 5 other browsers installed and none of them except Edge run background processes unless started (which I would prefer to keep to a minimum since they use resources)
I figured out that by going to the Services Manager I can set it to 'disabled' which stops it until I need to open the browser but when I restart my PC it starts running again despite being 'disabled'
Thanks
We cannot disable the aloha_service, as doing so may cause Aloha to function unstably. This service is essential to ensure the system runs smoothly.
Thank you for your understanding.
