VPN locks UI when in airplane mode or offline
Solved Benji ● 15 months ago
If you’re in airplane mode or do not have an internet connection the VPN permanently tries to connect despite the fact it will never succeed.
The problem is you cannot touch any area of the UI to cancel or go elsewhere like settings to turn it off.
I was offline and wanted to go to my Downloads to watch a movie on the plane but Aloha was rendered unusable.
Replies (1)
Good day,
Thanks for your feedback. This bug is known to us and we are working to sort it out, so please stay tuned! We are hoping to release fix with the next couple of versions 🤞
Regards,
