Send tab to device not working
Solved Edgar ibarra ● 13 months ago
Send to device asks me to sign in but doesn't work even when I do. Sending from iPhone to windows. Sync is on. It used to work and stopped out of now where
Replies (2)
2
Good day,
Thanks for your feedback. Are you logged in both devices with Aloha Profile account? If so, is tabs sync enabled on both devices?
Regards,
Hello yes and yes I even signed out on both devices and signed back in
In this case, on your windows - tap 3 dot icon (upper right corner) and then navigate to 'tabs from other devices' (pls see attachment), from there on you can open all your tabs from iPhone ✨
