VPN not connecting
Solved zakica ● 4 months ago
In Pakistan it is showing error E4, I removed the VPN Profile, Re started App and Phone both but nothig works, phone is Iphone Pro 15, latest updated, iOS and Aloha App.
Need Help
Replies (1)
Hello, please try to reconnect.
If that doesn’t help, you may want to consider upgrading to a Premium subscription. It gives you access to multiple server locations, increasing your chances of connecting through a server in Pakistan if that’s the location you need. Please note that internet access in Pakistan may be affected by restrictions imposed by local authorities, which can impact VPN connectivity regardless of the provider.
Best,
