Vpn feature suggestions
Under Consideration Josh Murphy 12 hours ago
Hello Aloha VPN team,
I have been testing Aloha VPN Premium and I would like to share some feedback and feature suggestions.
First of all, I like the VPN experience so far. I especially appreciate that the VPN appears to use a real system VPN profile on Android, not just a browser-only proxy solution. I also tested for DNS leaks and WebRTC leaks, and everything worked correctly.
A few suggestions that would make the VPN experience even better:
1. Android Always-on VPN / Kill Switch support
It would be great if Aloha VPN could support Android's native "Always-on VPN" and "Block connections without VPN" features. This would give users stronger protection against accidental IP leaks when the VPN disconnects.
2. Better background stability
Currently, the VPN may disconnect if the Aloha app is closed from recent apps. It would be useful to have a stronger background VPN service, similar to dedicated VPN apps, so users do not need to keep the app open.
3. Auto-connect options
More advanced options would be welcome:
- Connect on device startup
- Auto-reconnect after network changes
- Auto-connect on untrusted WiFi networks
4. More information about VPN servers
The VPN connection details are interesting, but it would be useful to show:
- server location
- hosting provider / data center information
- approximate latency
- current exit IP details
5. Connection protection testing
A built-in "VPN leak test" or "connection protection check" would be a great feature for users who want to verify that their connection is protected.
Overall, I like the direction of Aloha VPN. It feels different from many traditional VPN services, and with stronger kill switch/background features it could become an even more complete privacy solution.
Thank you for your work.
Access denied
