Italy VPN is not working. Please fix as soon as possible.
Solved Bora Culhan ● 5 years ago
I've been trying to connect to the Italy VPN server as a premium user. It seems like a VPN connection is established however, I am not able to surf on the web whatsoever.
Replies (7)
Hi there,
Thanks for your feedback. We will need a bit more detail to be able to assist you, so please answer the following:
- what Aloha version do you currently have?
- what OS version do you have on your device?
Thanks in advance!
I'm using 3.0.1 version of Aloha and IOS 13.3.1
Do you experience this behaviour with Italian servers only or other country servers as well?
Only Italian servers unfortunately.
We tested it, and it works fine for us, so please provide some specifics:
  1. You can’t open all web pages or specific ones? Please forward links to pages which are not working
  2. Please connect to Italian VPN server and run a speed test, for example use this platform -https://fast.com/ then please share result with us.
Thank you!
I can't even open any web page. Therefore, I can't do a speed test. It took 2 minutes to connect to fast.com and it gave me an error.
Hi there,
We have fixed the issue. Please relaunch app and try again. it should work fine!
