Upvote 7
Reached Maximum Connected Devices
Solved xKhalid ● 5 years ago
I have reached Maximum Connected Devices I need to remove these devices how can I remove them? Any help.
Replies (20)
Hi there,
We have done it!
Regards,
My email is letai3344@gmail.com
I needed help with the same issue my email or account is octavienmoore.com@icloud.com
I have also reached maximum connected devices. Please help me. Samdeethroa3@gmail.com
Done!
I need help with this too too many devices
We have fixed it, please try again!
Hi, can you please fix mine too, it says the same thing. Thanks.
Done!
Tolong bantu saya.. saya tidak bisa login
I have reached Maximum Connected Devices I need to remove devices please help.
nick.wslau@gmail.com
Thanks.
Done!
Kato.tarek.kt@gmail.com
Done!
Same problem
kim8pssypr@privaterelay.applied.com
I Need That too Reached Maximum Connected Devices Arda.rtzp21@gmail.com email
Done 👍
Thanks but I like this apps
I need to remove it too.
Done 👍
I have reached maximum connected devices too and I need help my account or email is
Hi there,
What is your log in address please?
Log in address? I’m confused but my username and or email I signed up with was
here is an example how it should look: example@privaterelay.appleid.com
Oh so like this? Sorry for the confusion I just thought it would be an easy fix.
dpdcnf87nuprivatrelay@gmail.com
Please do the following:
  1. Open iOS settings
  2. Tap apple account in the upper corner
  3. Tap password and security
  4. Tap apps using apple id
  5. Choose Aloha
  6. There you will find private email witch was generated for you during registration
tpiyunxmhr@privaterelay.appleid.com
Its fixed! Please try again.
Same problem
Done 👍
My email is Mazen7iphone@gmail.com
Done 👍
Reached Maximum Connected DevicesMy account is - godofallthings369@gmail.com
Done!
Я достиг максимального количества подключенных устройств. Мне нужно удалить эти устройства, как я могу их удалить? 905744@gmail.com
Done!
Hi there,
We will need your apple id email, example -> example@privaterelay.appleid.com
please hepe me
Done!
Pls count me in, mine exceeded too.
Mine too please my email is alpktl69@gmail.com
I have the same problem my apple id is wmunoz9412@gmail.com or tnxt9bu72s@privaterelay.appleid.com.
Done!
Please me too ,i can't sign into my new phone
Done!
Hello. Same problem with my account
Done!
Need help, won't let me log into my account, says maximum Devices Reached
Matthew.owens27@yahoo.com
nafeesshahriar278@gmail.com
英語じゃあ解らんよ
2021年3月17日(水) 18:00 Aloha Browser <support@alohabrowser.com>:
I am having the same problem maximum devices reached. But I signed up with my AppleID, and I think they used a masked one and I don't know where to get it.
But here's my AppleID: mnsor-3000@hotmail.com
Hi there,
The email format should look like this: example@privaterelay.applied.com
Thanks,
I can't find it anywhere even in my subscriptions tap in the app store.
Thank you, it is: rg72whcnnx@privaterelay.appleid.com
Its fixed 👍
Max devices devices exceeded, pls help
Sirajulmonir03@gmail.com
hoobe.q8@gmail.com
Max devices reached, please help.
You can clear devices in here: https://alohaprofile.com/login.html
Please help! It says my email and/or password is invalid. I just reset my password and my email is correct: williamswade698@gmail.com
Again, pls help to resolve the max devices exceeded issue🙏 thx
