Installation Failed for PC
Solved Guest ● 5 years ago
Hi, I'm using windows 10 and i have downloaded 3-4 times and whenever I try to install the browser it shows up a message saying "Installation Failed". I was previously using the browser in an older pc with windows 10 and it worked perfectly on that.
Replies (2)
Good day,
1. This can happen if you haven't got enough storage on C: drive (check free space please)
2. Please add file C:\Users\%USER_NAME%\AppData\Local\Temp\aloha_installer.txt
Regards,
Aloha team
I don't understand.
Please check if your pc has enough available storage. Then:
Copy this -> C:\Users\%USER_NAME%\AppData\Local\Temp\aloha_installer.txt and paste it in your PC search and change USER_NAME to your name. Once it finds the file, please attach to this chat so we can look into it. Thanks,
The issue was with my version of windows, after an update I downloaded and successfully installed the browser, Thankyou.
Great! Thanks for the thumbs up! Take care,
