Multithread downloading
The multithread downloading is an advanced download option. It has flexible possibilities for different cases.
We recommend using it this way:
  • For one large file, the best option is eight threads. It will have the highest performance for one file. However, due to technical limitations, other files will only utilize one thread, resulting in a slower download process.
  • For a few small-sized files, for example, TV series or short videos, for the best result, set it to 4 threads. The browser will download 2-3 files using multithread with maximum speed.
  • If you download small files in bulk, pictures, songs, etc., two threads are the best option to download files simultaneously.
