Multithread downloading
The multithread downloading is an advanced download option. It has a flexible possibilities for different cases.
We recommend using it this way:
  • For one large file the best option is eight threads. It will have the highest performance for one file. However, due to technical restrictions, other files will use only one thread and the download process will be slower.
  • For a few small-sized files, for example TV series or short videos - for best result set it to 4 threads. The browser will download 2-3 files using multithread with maximum speed.
  • If you download small files in bulk, pictures, songs, etc. two threads is the best option to download files simultaneously.
