Player controls gone
Completed Brent Schwarz ● 4 years ago
Version 4.0.5 no longer had slider controls for volume and brightness. Also, video scrub scrolling only jumps forward by 10 seconds when swiping. And lastly, the little download arrow vanished. Why remove all of the great features? App is no different than the other browsers now.
Replies (2)
Hi there,
Are you on iOS version 16?
Yea that was the issue. Works as it should on another device. Thank you. Any idea why this happens or if there will be an update?
Please note that iOS 16 is running on beta at the moment and various errors and bugs are expected at this stage. There will be changes and fixes introduced along the way.
Kind regards,
