Upvote 5
Downloads not working since Premium purchase
Solved Yoko D. ● 20 months ago
Aloha Downloads were working fine until I purchased Premium, not when starting a download it keeps „waiting“ for a while and then either states „Error“ immediately or starts downloading, but the speed reduces to and stays at 0byte/s. Any help is appreciated because I was looking forward to the premium features such as fast download speeds
Replies (6)
2
Hello,
Thank you for your feedback. Please provide/answer the following:
- Forward video links with download error
- What Aloha Version do you have?
- What Android/iOS version do you use?
Thank you,
My aloha version is 7.12.1
Hi, thanks for your reply
Aloha Version 6.7.0 and retried with 7.0.0
iOS Version 16.6.1
Link: https://www.eporner.com/video-FEuDJvovzqF/charlotte-sartre-dp/
Thanks for your help!
2
Please disable Adblock toggle in Aloha Settings and try downloading again, it should work fine 👍
Hi, thanks for the advice.
However, there‘s only been a slight improvement since I disabled the adblock feature: the download does start after a while being stuck on waiting, and once it does it‘s quite slow (200-500 kb/s) and stops fairly quickly saying „Error“ download failed
Please also disable background downloading, it seems to work much better with this feature off, adblock can be enabled.
When you buy a premium, the settings change and this may affect the download of files from some sites. Therefore, it is worth trying to switch on these settings:
