Waiting for Connection
Solved Mateosdad 12 months ago
App is no longer downloading and I have tried various sites. Now it just spins and says “waiting for connection “
Replies (3)
Hello,
Thank you for your feedback. Please provide/answer the following:
- Forward video links with download error
- What Aloha Version do you have?
- What Android/iOS version do you use?
Thank you,
1. It’s any video but here is an example https://mymusclevideo.com/63864/muscle-2/
2. I’m using version 7.9.0
3. I am using Apple IOS and the latest version. I’m up to date on iOS and my aloha app is up to date.
Thanks for the link. Any video on this site or on some other sites too?
I’m realizing that’s it’s now any video on any site. I will screenshot the last 4 videos I’ve tried to download, the links to their site, the version of iOS being used, the model of phone I’m using as well as the version of Aloha being used. I’ve read a few of your other tickets and realize you guys are precise on what it is you’d like us to provide to you and not adhering to that can prolong the matter getting fixed potentially have your ticket thrown out altogether.
Quoting Locutus of Borg- “Resistance is futile”
These are screenshots illustrating my model of iPhone, the version of iOS being used, the latest version of aloha out and the version of aloha I’m using. It may also illustrate that there are no updates needed for the app but that is assumed by my depiction of most of alohas updates shown chronologically and my version being the last
Thanks for additional info!
I’ve checked all the links and they’re working fine.
First, please check if the "Use mobile data" toggle is enabled.
After switching it on, go back to Downloads and tap ▶ on any item showing "waiting for connection".
If that doesn’t work, please go to:
iOS Settings → Cellular → Cellular Data Usage (Apps)
Make sure the toggle for Aloha is turned ON.
Let me know how it goes!
It’s funny I received your suggestion when I did as about a half hour ago I did this very thing. Unfortunately it has not resolved the issue.
If there is anything else you might suggest other than throwing the phone away, let me know. I’m saving the finality of throwing the phone out of a moving vehicle for next week.
Hey, I just wanted to let you know that it’s BAU. I changed my SIM card,, had my mobile provider reset a few things and now it’s up and running.
Thanks for listening to me winge and moan and for telling me off of the ledge.
Til next time…..
Ok great, thanks for letting me know!
This screenshots illustrate how downloads are doing the same thing and I’ve provided various formats I’m downloading just to spice things up a little. Initially I thought it would help rule out it being a format issue but by it saying “waiting for connection”would imply in and of itself the issue does not pertain to formatting
https://www.myvidster.com/video/536235318/YOUR_THOTTY_DADDY_Manly_Butt_Fucker_Driller_Daddy_Destroys_Cockhungry_Bottoms_Gay_Porn_Anal_19
https://coomer.st/onlyfans/user/yourthottydad2.0/post/461937745
https://www.myvidster.com/video/536266045/YOUR_THOTTY_DADDY_Manly_Butt_Fucker_Driller_Daddy_Destroys_Cockhungry_Bottoms_Gay_Porn_Anal_13
