Slow downloads when using mobile data 4G
Solved Salim Alsaadi ● 14 months ago
I have the premium version of the app, but the downloads using mobile data 4G is so slow. If I use WIFI the downloads speed is fine. Only when using 4G everything is slow. What is the problem?
Replies (2)
Good day,
Thanks for your feedback.
The slow download speed on 4G is likely due to one of these reasons:
  • Weak mobile signal
  • Network congestion in your area
  • Your carrier may be throttling speeds after high data usage
  • Other apps using data in the background
  • Carrier restrictions for downloads over mobile data
  • Incorrect network settings
Try restarting your phone, running a speed test, or contacting your carrier to check for any limits or issues.
Regards,
I don’t have a problem with internet speed, it is more than 250MBs. Everything was fine before, but a few months ago I have this issue till now. I don’t know why? I tried everything possible. The problem is not solved.
What Aloha and OS versions do you have and on what website do you experience slow downloading speed with mobile data?
Here is a screenshot of Aloha version and I’m using IOS 18.6.2, I have this issue in multiple websites
