Delete Network
1. Go to Wallet
2. Tap Settings icon in the upper right corner
3. Enter Networks section
4. Tap any Network in the list
5. Hit the Bin icon in the upper right corner to delete the Network.
6. Confirm it by tapping Delete in the pop up menu
Is article helpful?
