Add Network
  1. Open Aloha Wallet
  2. On the main wallet screen, click the settings icon located in the upper right corner:
    1. Select "Networks," and you will see a list of existing networks and "Add" button to add a new network in the upper right corner. Fill in the fields following the instructions to add the Binance Smart Chain network;
    2. Name: Binance Smart Chain:
    3. RPC URL: https://bsc-dataseed.binance.org/
    4. ChainID will be automatically filled in.
    5. Symbol: BNB
    6. Block Explorer URL: https://bscscan.com (or another source of information).
  3. Click the "Add" button in the upper right corner to save the Binance Smart Chain settings. Afterwards, you will see a network switch dialog box. If you wish to switch to the new network, you can do so with a single click. Now, you can send, receive, and store Binance Smart Chain and tokens based on this network in your Aloha Wallet:
How to add the Binance Smart Chain (BSC) network using the web3 website:
  1. Open the web3 website in Aloha Browser, where you can add a network. For example, we will use www.chainlist.org.
  2. Go to the website and find the list of networks
  3. Pick any Network and tap "Connect Wallet":
  4. Afterwards, you will see a dialog box with "Add" and "Reject" buttons. To add the network, swipe the "Add" button:
  5. The network will be automatically added, and if necessary, you can switch to the added network using the "Switch" button, which will appear immediately after adding.
Is article helpful?
