Unhide NFT
1. Go to Aloha Wallet
2. In the NFT menu, tap the 3-dot icon
3. Then tap View Hidden
4. Select the hidden NFT from the list that you wish to unhide
5. Tap 3-dot icon in the right corner - tap Unhide.
Is article helpful?
